Pewnie wielu z was już to zestawienie widział a le pewnie wielu nie dlatego wklejam. Jest tu pare rzeczy które dają do myslenia...
Turbo KA24DE [more info]
Swap Difficulty: 1
Aftermarket Support: 3
Donor Car(s): S13 (1991+ US model), S14 (all US models), Hardbody (pick-up)
Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install*
Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install*
Redline: 7,500rpm
Good: cheap, fast, less work than a swap
Bad: reliability issues in some cases when running med/high boost sustained
Engine Cost: $800-1,500 (a few hundred more if it's rebuilt or has some parts upgraded/strengthened)
Install Cost: n/a (everything is installed other than turbo) OR $200-500 (to install a new KA where your old KA was)
Modified Horsepower Ceiling (stock internals): 250-350hp
CA18DE-T [more info]
Swap Difficulty: 4
Aftermarket Support: 4
Donor Car(s): Silvia (1989-1990) and 180sx (japan)
Stock Horsepower: 173hp (175ps) @ 6400rpm
Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm
Redline: 8,500rpm
Good: higher redline and cheaper than SR20DET with about the same potential, iron block
Bad: less parts support (esp in the US), weaker head gasket than SR20DET
Engine Cost: $2,000-3,000
Install Cost: $1,000-2,000
Modified Horsepower Ceiling (stock internals): 300-400hp
SR20DE-T (S13) [more info]
Swap Difficulty: 4
Donor Car(s): Silvia K (japan), Kouki 180SX
Stock HP: 203hp (205ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm
Redline: 7,500rpm
Good: great output for the price with very good potential
Bad: less output than an RB25 and weakest (stock) SR20DET, aluminum block
Engine Cost: $2,500-3,500
Modified Horsepower Ceiling (stock internals): 350-450hp
SR20DE-T (S14) [more info]
Swap Difficulty: 4
Stock Horsepower: 217hp (220ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm
Redline: 7,500rpm
Good: slightly better output than the S13 SR20DET
Bad: VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $4,000-5,000
Modified Horsepower Ceiling (stock internals): 350-500hp
SR20DE-T (S15) [more info]
Swap Difficulty: 4
Stock Horsepower: 247hp (250ps) @ 6400rpm
Stock Torque: 202lb/ft @ 4800rpm
Redline: 7,500rpm
Good: ~250hp stock, usually very low mileage, better condition than s13 or s14 engines (in most cases)
Bad: 6 speed tranny is somewhat weak, so if you plan to increase the hp much you want to swap it for the ka tranny or an s13/14 tranny, VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $5,000-6,000
RB20DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline R31
Stock Horsepower: 207hp (210ps) @ 5600rpm
Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm
Redline: 8,000rpm
Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block
Bad: cost
Engine Cost: $2,500-3,000
Install Cost: $2,000-2,500
Aftermarket Support: Fair
Modified Horsepower Ceiling (stock internals): 400-450hp
RB25DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline GT-S (R32, R33, R34)
Stock Horsepower: 247hp (250ps) @ 6000rpm
Stock Torque: 217lb/ft (30kgm) @ 4800rpm
Redline: 8,000rpm
Bad: cost, replacement parts availability
Engine Cost: $5,000-6,500
Install Cost: $2,500-3,000
RB26DE-TT [more info]
Swap Difficulty: 2
Donor Car(s): Skyline GTR (R32,R33,R34)
Stock Horsepower: 316hp (320ps) @ 6800rpm
Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm
Redline: 8,000rpm
Good: huge potential, high horsepower stock, iron block
Bad: AWD tranny can't be used without lots of modification and custom work. TT setup can be retained, but it's much easier to convert it to a single turbo. RB25 tranny (5 speed rather than RB26 6 speed) because of clearence and fit issues.
Engine Cost: $7,000-8,000
Install Cost: ~$3,000 (AWD and TT setup will be in excess of $15,000 for install)
Modified Horsepower Ceiling (stock internals): 500-600hp
RB30DE-T (hybrid) [more info | head conversion how-to]
Swap Difficulty: 3
Donor Car(s): Australian (block; RB30ET 3.0L SOHC) / Skyline GTR or GTS-T (head; RB25, RB26, or RB20)
Stock Horsepower: ?hp (?ps) @ ???rpm
Stock Torque: ?lb/ft (?kgm) @ ???rpm
Redline:
Good: good potential, iron block, cheap engine, when modified produces large hp numbers at low revs
Bad: age, replacement parts availability, block is hard to find, RB20 head requires lots of work to fit correctly
Engine Cost: n/a
Install Cost: ~3,000
Modified Horsepower Ceiling (stock internals): 350-400hp
VG30DE-TT [more info]
Swap Difficulty: 3
Donor Car(s): 300ZX TT
Stock Horsepower: 300hp (304ps) @ 6400rpm
Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm
Redline:
Good: very unique and a decent engine for heavy modification
Bad: huge cost for custom fabrication
Engine Cost: $4,000-6,000
Install Cost: $10,000-20,000+
Modified Horsepower Ceiling (stock internals): 450-550hp
VQ30DE(K) [more info]
Swap Difficulty: 2
Donor Car(s): VQ30DE in A32 Maxima(1995-1999 US model), VQ30DEK in A33 Maxima(2000-2001 US models)
Stock Horsepower: 190 hp @ 5600 rpm(A32 VQ30DE), 222hp @ 6400rpm(A33 VQ30DEK)
Stock Torque: 205 lb ft @ 4000 rpm(A32 VQ30DE), 217 lb ft @ 4000rpm(A33 VQ30DEK)
Redline: 8,000 rpm
Good: Can be cheap, good low-end, lightweight, very turbo friendly for an NA motor.
Bad: Aluminum block, lack of top end on non DEK motors. Note: Can be fixed with variable intake manifold from Courtesy Nissan. Needs Pathfinder tranny.
Engine Cost: $400+
Install Cost: N/A
VQ35DE [more info]
Swap Difficulty: 2
Aftermarket Support: 2
Donor Car(s): 350Z, G35, kouki Maxima, kouki Altima, kouki Pathfinder
Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima)
Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima)
Redline: 6,600rpm
Bad: huge cost for custom fabrication, engine taken from a kouki Altima or Maxima will need a RWD trans
Engine Cost: $5,000-7,500
Modified Horsepower Ceiling (stock internals): n/a (350-400hp est.)
Nissanowskie silniki i ich potencjały
- jarkowy
- Założyciel Klubu
znam ta stronke ..... niema to jak hAmerykanski optymizm
"CA18DE-T (...) Modified Horsepower Ceiling (stock internals): 300-400hp"
good luck gangsta doggz
Hollaz to the West Side!!
- jarkowy
- Założyciel Klubu
TAk ale to jeszcze nic.
Redline 8500obr/min
Fakt ze ja czasmai swojego zakręce do 8000 ale robie to czasami a normalnie chipem ustawiam sobie limit na 7200
Kto jest odważny zeby wypóbować czy jego silnki pokręci się z 8500 na kążdym biegu? - zrobie mu chipa za darmo
Redline 8500obr/min
Jezeli chodzi o tuning CA to lepiej pytac "fajfoklokow" , Amerykance wogole niekojaza tego silnika......
- Adi
he to ja i tak zawsze najlepszy albo najglupszy u mnie w primerze 2.0 GT SR20 na gazie wykrecalem tak ze brakowaBo skali ale bylo napewno z 9500 jak nie wiecej troszeczke
bo wskazowka stawala na dole w pionie a zegar mam 9000 do 3 biedu tak robilem pozniej to juz predkosci sie zaczynaly
Skaut
Jak tys to zrobil?? Ja mam ten sam woz ale wiem ze przy 6500rpm juz strasznie zdycha...wykrecalem tak ze brakowaBo skali ale bylo napewno z 9500
no przeciez mówi ze na gazie!!na benzie odetnie wiadomoSkaut pisze:Jak tys to zrobil?? Ja mam ten sam woz ale wiem ze przy 6500rpm juz strasznie zdycha...wykrecalem tak ze brakowaBo skali ale bylo napewno z 9500
- Coobcio
Moj SR20De tylko do 6500...
Ps. te 7850 to są wskazania obrotomierza w rzeczywistości jest 7500obr.min.
Ps2. a jaka jest seryjna wytrzymalość SR20De ??
Na trubinie bez odperzania 250 kucy osiagnie ??
- Adi
na beznynie mi odcina tak ok 7200 a na gazie niema ograniczec nic nie odetnie chyba ze walki wyrwie korba kolano pokarze czy cos w tym stylu
no i dodam ze wszystko w nim seria tylko stozek siedzi a tak zero przerobek a i wywalilem katalizator
chuckie
I jeszcze jedno bardzo mnie dziwi. Napisali że na stockowych bebechach w CA18DET to idzie zrobić 300-400hp.... Nie słyszałem choć bardzo ciekawe. Na forum na sxoc dowiedziałem sie że te silniczki wytrzymują 280-300 ale nie 400hp!? I jeszcze jedno Ciekawi mnie ten silnik RB30DET - wyłącznie czytałem, mało wiadomości, nigdy go nie widziałem i nie słyszałem żeby ktoś to wogóle tuningował - macie jakieś linki??
No dobra może ja sie nie znam ale to auto z wyglądu ma silnik 1,8 a napisane jest jak wół 2,0l.
Patent z układem ssącym jest wykręcony ,
A dodatkowo ma taki sam wlot na masce jak ja ale naszczeście w innym miejscu
http://allegro.pl/show_item.php?item=45931323
Może to ktoś od nas??
- Coobcio
Ale to pięknie musi chodzi laga pewnie nie ma a temperatura poweitrza wylatującego z turbiny pewno lekko przekracza ze 120*C ale co tam
- Coobcio
Tak ale S12 miało doladowanie 0,35 bara a ta T28 myślę ze jest ustawiona na 0,6 jak ni
Więc może być ciepło...
