Złącze ECU w S13 i S14 (chyba tylko do 96r)
[center] [/center]
Styki w S13
1 Coil pack 1 output (via power transistor Unit)
2 Coil pack 2 output (via power transistor Unit)
3 Coil pack 3 output (via power transistor Unit)
5 Boost pressure control solenoid (domestic Japanese cars only, not Euro models)
6 Air conditioner relay
7 Tacho drive output to tachometer
8 Variable intake butterfly control solenoid (domestic Japanese cars only, not Euro models)
10 Ground
11 Coil pack 4 output (via power transistor Unit)
16 ECCS system relay (earth = on)
17 Injector pulse duty output (to trip computer for fuel usage measurement)
18 Fuel pump relay (earth = on)
20 Ground
23 Knock sensor input
26 Air flow meter pin B (ground ?)
27 Air flow meter pin A
28 Coolant temp sensor input
29 Oxygen sensor input (unleaded catalyzer model only)
30 Sensor earth
32 Check lamp output to check connector (green)
33 Check lamp output to check connector (red)
37 Air flow meter pin D (non cat models ? )
38 Throttle Position Sensor potentiometer (wiper)
41 Crank angle sensor 180 deg input
42 Crank angle sensor 1 deg input
43 start signal (cranking) from ignition switch
44 Neutral(manual) / park(auto) gearbox switch signal
45 Ignition On switch signal
46 Air conditioner thermostat input (ECU controls AC activation)
47 To check connector ?????
48 TPS potentiometer battery output (5 volt?)
49 Battery from ECCS relay
50 Ground
51 Crank angle sensor 180 deg input
52 Crank angle sensor 1 deg input
53 Speed sensor input via the speedometer
54 TPS switch (throttle idle position)
55 Ambient air temp sensor input (sensor is in front of radiator)
56 ?????
57 TPS switch (full throttle position)Auto trans? (kick down switch)
58 battery, unswitched
59 battery from ECCS relay
60 Ground
101 Injector No 1 drive output
103 Injector No 3 drive output
106 AAC (aux/idle air control) valve output
107 Injector drive ground
108 Injector drive ground
109 Battery from ECCS relay
110 Injector No 2 drive output
111 ? CA18DET A/T ? or pressure reg control valve?
112 Injector No 4 drive output
115 Heater output for O2 sensor (unleaded catalyzer model only)
116 Injector drive ground
W moim aucie nie podłączone są 4,5,8,9,12,13,14,15,19,21,22,24,25,,29,31,,34,35,36,39,40,45,46,,102,104,105,113,114,115
Styki ECU w S14
3 Tachometer signal output
4 ECCS relay
5 Ignition pulse monitor (for trip comp ?)
6 Ignition Signal Ground
7 RX data (signal from Nissan Consult hand terminal)
8 Coil pack 3 output (via power transistor Unit)
9 Coil pack 4 output (via power transistor Unit)
10 -
11 -
12 A/T signal DT3 (autotrans gear select ?)
13 Ignition Signal Ground
14 CLK clock (timing signal) ?
15 TX data (signal to Nissan Consult hand terminal)
16 AFM Signal input (air flow meter)
17 AFM ground
18 Water temp sensor input
19 Oxygen Sensor input (O2)
20 TPS input (throttle position sensor)
21 Sensor ground
22 CAS 180deg signal (crank angle sensor)
23 CHK check (check start) ?
24 Monitor check lamp (Red) (fault code lamp output)
25 Exhaust over temp warning lamp output
26 Exhaust temp sensor input (behind the Cat)
27 Detonation sensor input (knock sensor)
28 TPS for A/T (kick down switch)
29 Sensor ground
30 CAS 180deg signal (crank angle sensor)
31 CAS 1deg signal (crank angle sensor)
32 Speed sensor input
33 -
34 START signal (from ignition switch)
35 A/T neutral switch input
36 IGN (ignition ON, from ignition switch)
37 TPS power output (power to throttle position sensor)
38 ECCS power
39 ECCS ground
40 CAS 1deg signal (crank angle sensor)
41 A/C on input (Air Con ON from A/C panel or climate control)
42 A/T signal DT1 (auto trans gear select ?)
43 Power steering switch (speed proportional control output)
44 A/T signal DT1 (auto trans gear select ?)
45 Ambient air temp sensor input
46 ECCS backup power
47 ECCS power
48 ECCS ground
102 EAI control solenoid output (EGR valve control ?)
104 Fuel pump relay output
105 Fuel pressure control module
106 A/C on output (Air Conditioner on relay signal)
107 Injector ground
108 Injector ground
109 Reverse electrical flow return circuit (alternator fail input ?)
111 Turbo boost pressure control solenoid (over boost cut ?)
113 AAC valve control (Auxiliary Air Control, idle speed control)
114 -
115 -
116 Injector ground
Złącza ECU
- jarkowy
- Założyciel Klubu
